Your power antenna relay is located under the valence panel at the rear hatch latch, to the left of the latch.
Thank you I appreciate your help. My winter job to repair the antenna which seems to have stuck halfway down and the motor kept running. Do you know if there is a repair kit available, as least I can now replace the fuse get the radio back.
Thanks again.
If the motor doesn't go full travel and engage the limit switch, the motor will continue to runthe antenna which seems to have stuck halfway down and the motor kept running.
