Hi guys. So, I just bought first Corvette. Its an 84 C4 in great shape but has no power steering at all.. I've replaced the power steering pump (and high pressure line.) filled and followed a general power steering bleeding procedure but as soon as I set the tires down it was obvious there was zero improvement. Still zero power steering. what am I missing here? All I can think is that either there is a special bleeding procedure I'm just unaware of or the rack and pinion is malfunctioning. I figured you guys here could probably spot my issue right away. any advice? thanks in advance
