Welcome to the CAC peterd.
If you haven’t had a chance to test drive a C4 and C5 back to back, that may be a factor in your decision. Some of the early C5s values are dropping more than I would’ve guessed. This Sunday I saw a ’98 Nassau Blue Coupe with 42,000 miles for $18,500. That’s a lot of car for little money. No matter what generation you settle on, they’re all fun cars, I’ve driven both generations and they’re great. I could move up to a C5, but I enjoy my ’96 LT4 too much.
I don’t know if it’s been mentioned yet, but if you’re concerned about the car appreciating in the long term, you will need documentation to back up the cars history. Ask the owners of the Corvettes your looking at about the paperwork that goes with the car.
If you were looking at a C4, you would want inquire about:
• Both black plastic Corvette key fobs and both sets of keys. They are both pricey to replace so make sure you ask
• Original window Sticker (repros can be had, but original is original)
• Build Sheet (repros can be had... again, original is original)
• Black leather owners manual -- Would have a pen light with CORVETTE silk-screened on it, post-it size pads with C4 Corvette logo, Predelivery Dealer Inspection check-off list, warranty information brochure
• Predelivery Dealer Inspection Check-off list. Will have check-offs that a tech would’ve done on the Corvette before delivery. Will have vin, mileage and anything done to the car listed; i.e. like adding windshield washer fluid. Would’ve been inserted into the black leather owners manual
• VHS video that came with the car (if applicable, not sure what year this started)
• Warranty paper work for Goodyear tires that came in the cars black leather case
• Linear Gauge static cling decal -- Was located in the lower right area of the main instrument cluster lens. Had function information of linear gauges in white ink on clear static cling decal.
• Emergency Brake information sleeve -- white boxed, heavy piece of paper that fit over the e-brake handle and had instructions for operation
• Key fob information sleeve -- white heavy paper that spare key fob rested in. Was kept in the cup holder compartment to the right of the shifter
• Check the RPO of the Corvette, make sure that if it had dual tops and it’s a coupe, your getting BOTH tops, transparent and body color. If the RPO sticker lists two tops and you don’t see the second, inquire where the second top is. Some people will sell a Corvette and not hand over the second top because they intend to sell it on ebay. They’re not cheap! Make sure you’re not being taken advantage of. Same thing if it’s a convertible, check the RPO codes. If it says hard top option, make sure the seller presents it to you. Convertible hard tops are expensive, they run over $2,000 to replace.
Keep us posted!
B17Crew
