RLDaily
OK, here's the deal. 1990 L98 133K miles
1st...I'm a licensed aircraft mechanic with about 20,000+ heavy maintenance hours on helicopters and fixed wing so I know my way around tools and stuff and I work on my car just like I would an aircraft, I have my tech manual open and I tag my parts...nuff said
I had a suspicion that the throttle body on my '90 L98 had never been cleaned and I was correct, it looked like it had bits of charcoal down its throat and when I removed it the backside looked like the darkside surface of the moon.
I cleaned the throttle body as described in "101 Projects for your Corvette 1984-1996" by using spray throttle body cleaner and a soft toothbrush and paintbrush...no scraping, scratching or anything like that. I also cleaned the ports on the plenum and they turned from dark brown/black to pretty aluminium.
I reinstalled with a new gasket of course (18 inlbs torque), hooked up the vacuum and water lines so on and so forth. Double and tripple checked connections.
The thing runs like a log wagon....Loping at idle and no power especially when trying to go into passing gear on the road...falls flat on its fanny...Oh yeah...fuel pressure 36-37 lbs at idle and open throttle.
Before I did this the thing would snap your neck going into passing gear and it was smooth at idle
