low-clearance ramps?
Glen Burnie, MD, USA
1986 Bright Red Coupe
Ok... here's a question I thought I had solved. What brand of ramps do you all use that are shallow enough to clear the Vette's airdam?
I bought a set of Rhino Ramps (which USED to have two separate inclined areas to clear low cars, but not now). The package showed a C5 Vette on the ramps, and they said they were specially made for low-clearance vehicles. However, when I set them down in front of my wheels yesterday, the airdam caught BADLY. In order to get them anywhere even close to the wheel I would have had to deflect the airdam a good two inches - and I don't want to contemplate bringing the car back down.
Do people just take off the airdam when using ramps, or are there other reasonable alternatives? I dislike jackstands for quick work - I spend more time raising/lowering the car than actually working on it.
Or is my car just riding lower than it should be?
Thanks...
[RICHR]
Rabbit
sonoma ca usa
2004 C5 coupe, MSGM & 2014 Cad SRX Crystal red
I believe some owners use 2X6'S
to get the front over the initial incline.
vms4evr
Durham, NC
2002 Flat Black Z06
Rich,
I can't remember the brand name of mine. I got them at Pep Boys a year ago. They come with a two-peice plastic setup for each side. For my sons car just 1 peice is enough to get the car on. For the Vette I need both peices. The second peice extends from the first. That extends the ramp and gets the body a little higher so it just makes it onto the ramps. But there isn't a lot of room.
If your car has been lowered at all it wouldn't make it on my ramps. It's that close...
Graham
Thanks - I'm going to try the 2x6 approach. Our local Pep Boys didn't have jack (no pun :) ) for ramps when I checked last year.
I really wish I could find a set of those old-style RhinoRamps :(.
[RICHR]
Just FYI, a couple lengths of 2x6 pressure treateds worked just fine. I was able to get onto the ramps with no scraping at all. Thanks for the advice!
[RICHR]
That's what I'd call overkill... I'd prefer a small lift instead. Less space, stores easier.
[RICHR]
jeepie
Dunmore, Pa.
1991 Coupe Blk/Blk
I ordered a set from one of the vette magazines, I think they are called ultra ramps. They come with the plastic pieces that reduce the incline. The front airdam just rubs a little doesn't really flex it much. The only problem is that the tires barely fit in the ramps, it takes a couple attempts, with someone watching, to get them centered. They do work, but for ramps that are advertised for c4's one would think they would perfect.
F
FX3FX3
RAMPS
For the front, push them in against the tires. I own them...i got no problems with them
I was, and that's when the skirts were rubbing. The answer turns out to be that later C4's have higher front skirts. My Bro-in-law's 93 does *NOT* scrape, and his skirts are at least an inch higher than my 86. We had the two cars side-by-side Sunday. So your 92 probably has the different skirts as well - his whole front diffuser/airdam was different to pull air differently into the radiator, so I am gathering this is an LT-1 thing.
[RICHR[
C
C V Man
Hmmm....
My '95 scrapes those same ramps!
What's up with that?
Maybe my tires were flat. Or maybe my tires have too low of a profile. Or maybe my garage floor is higher than yours. Or maybe my car is a low-rider. Or.....
