J
		jpanek
Hey Guys,
My low coolant warning light does not light up during the key on-engine off bulb check before starting the car. The bulb was swapped with a known good one and the circuit board does not appear to have a cracked trace in the back. The surge tank is new and its low coolant detector is plugged in.
Do your low coolant warning lights turn on then off when you start your cars? If so, what could be causing mine not to light up?
