B
basilio
The oil pressure suddenly began to read low on the instrument panel. 0 psi at idle and up to 15 psi at 2000 rpm. The red light comes on below 8 psi. The oil pressure sensor was replaced without improvement on the panel. When the wire to the sensor is disconnected, the gauge reads 80 in "run". When the wire is checked for short to ground-- it is not shorted to ground. It sounds like the instrument panel? The engine runs fine without any problems. How can I be absolutely sure without taking off the cluster that it is the cluster? Could it be a connector to the cluster? Can the car be driven without any untoward problems without the cluster in place to have it repaired or replaced? I am worried about damage to the ecm. I have the factory diagnosis manuals but it is vague in the way it is written. Any advice would be appreciated. Thanks.
