O
okie
Finally, I got my 88 Vette back from the wrench. He changed the oil pump and both sending units, but it did very little to help the oil pressure.
At 60 MPH the Oil Pressure (using Moble 1) is pretty steady at 35 PSI, but once again at idle in gear with the AC on it drops to 8-10 PSI. Since the pump was replaced it no longer drops below 5 PSI and there is no longer a low oil pressure warning light, but still, after $500.00 worth of labor and parts I am rather disappointed.
Is there anything else that could cause the low readings, and do any of you feel that this may cause engine failure? I have only driven the car about 500 miles since I got it, and in that short amount of miles I can't tell if it is using oil, but I don't really think it is.
Sorry to be so long getting back to you guys but I have been on the road for a couple of weeks and just now got to drive the car again.
bp
bp
