I am trying to remove the left hand lower control arm to replace the lower ball joint. How do you remove the bolt closest to the drivers door? The bolt head hits part of the frame with most of the threads still in the joint. Is there something else that I need to take apart to allow room for the bolt to be removed all the way? This is the only thing keeping me from removing the lower control arm. Any help appreciated. Thanks ES
