lower radiator baffle
  • Thread starter Thread starter firefytr
F
firefytr
Help, how do you change the lower radiator baffle of a 84. I can see the bolts on the inside sides, but cannot see how to get to the heads on the outside. Any help would be appreciated.
There are some guys in here with 84's. I'm not sure what you mean by "baffle" As you know the 84 is kind of it's own compared to other C4's and I'm not familiar with the differences accept the hood and crossfire and a few other things. If you don't get an answer soon I think you should repost the question to 84 owners. Good luck and someone will help you.
I've had the front end of my '84 all apart, and don't understand the problem. Some of the "bolts" are attached to metal strips, so you don't need to hold on to the "head" of the "bolt" to remove the nut. The only thing you need is another elbow in the middle of your forearm!
You Got that Right!!:D junk!!
