chevyaddict
We just completed a rebuild on the rear-end unit and have also put a new rear spring in the back. The car now looks like a stinkbug! I plan on completely rebuilding the front suspension but in any case, I would lower the front if it was as high as the back - down to at least its stock height. I have tightened the bolts on each side of the rear spring the farthest they can be and still I have about 6 inches or so of space between the tires and wheel well. Furthermore, I have adjusted all I can to get the tires to be aligned and they still toe in a little due to the height. I was thinking of just getting shorter bolts for each side but this would cause the spring to be "overtightened" I think and make for a real rough ride. Is this my only option? Any suggestions?
