G Winter
I just looked up the oiling diagram. The oil passes through the filter then has two choices, crank or upper engine. I think if the engine oiling wasn't primed then the oil might take the path of least resistance first , which would be upper engine with no oil to create a back pressure. Combined with oil passages draining during the tear down you could get bearing starving. I would almost bet that it is the front rod bearing that go , I think they are the last in line to get oil.
I always prime and engine if any oil passages have been opened.
I was looking at the zr1 engine. After more research I found an oil passage diagram the seem to indicate that the oil comes to the main bearings from the cam bearings. After seeing this I remember when installing cam bearings they must be oriented correctly to get the proper oil flow. Someone jump in and correct me if my memory is wrong on this.
Glenn
Glenn
