formul8
I know there is a separate code for the KM failure, but I replaced the knock sensors and all the wiring checks out ok. DTC 43 keeps coming up.
There is an exhaust leak under the car, but I will be replacing the exhaust anyways. I can tell by the way it runs that timing is being pulled out.
If the KS sees a lot of knock, will the DTC show up? Will adding an LT4 KM help?
