jeepcoma
New member
Since I got my LT4 at only 8,000 miles, I figured I'd start doing oil analyses to see how it holds up as the years continue to tick by. Hopefully the results will be, if not useful, then interesting. I'm also recording all fuel fill-ups so I might add some charts here as well, just to keep a log somewhere. My LT1 Camaro has almost 200k miles now, I got it at 80k, and wish I had a better history to see how things are going (it does run like a raped ape still). So, I hope to have some more information about this wonderful LT4 as time goes by.
All testing by Blackstone Labs.
First analysis. I guessed the oil had about 4k miles on it. This was after our road trip up back from Orlando, and just a couple other highway trips. 99% highway mileage. Probably didn't need to change it, but I try to do all my oil changes at the start of Spring and Fall so I don't forget.
I had to figure out how to get enough room under the car to actually reach the oil pan plug and filter, so I had to start it and move it around a few times, which I noted to the lab in case of fuel contamination.
I also wanted to do a raw oil analysis, before adding Castrol Syntec 0W-40 "European Formula". This oil appears to be pretty well recommended on certain forums. If anything, at least I can serve as a benchmark for others. Science! At the time of oil change, I also did something possibly foolish and got a "lifetime" oil filter. After considerable research (most of which consisted of people saying either "I bought one and like it" or "I could buy X oil filters for Y dollars each for the price of that thing!!!") I went with the K&P unit. We will see how it goes. I have to clean it once a year, big whoop. And I'll have some real data to add to the pissing contest about stainless mesh filters.
It sure looks nice.
The act of starting the engine just to put the car on ramps might have led to a little fuel
dilution. It didn't, but had there been a little fuel in this oil, we wouldn't have worried. Ideally, you'll drive the
car right on the ramps when you get back from your drive, turn it off, let it cool, and then sample the oil
before starting the engine. That's okay if that doesn't happen. Your engine looks great. Metals are all fine
compared to averages, which are based on about 3,300 miles on the oil. The TBN was good at 5.3, since
1.0 is low. A run of 6,000 miles should be fine.
It sure looks nice.
This looks like a good sample of virgin Castrol Edge. The viscosity is correct for 0W/40 oil,
and there are no signs of harmful contaminants. The main detergent/dispersant additives are calcium and
magnesium, while zinc and phosphorus are anti-wear additives. This is a good level of additives, and it
should do well in your LT4 engine. We did find a little more metal in this oil than we typically see from virgin
samples, but nothing here is what we'd call a problem level. The TBN is 8.0, so you're starting out with
plenty of active additive. Looks like good oil!
