I
insiswe
The vacumn routing in the 1991 manual is not clear as to the correct routing of of secondary vacumn and 1/4 inch pipes specifically to the purge solinoid under the plenum (this car has the purge cannister at the rear).Does a clear drawing exist for the 1991 engine with purge solinoid under the plenum.The drawing on zr1.net is also for a 1990 with purge cannister left front
