MAF sensor on '90 L98 engine?
  • Thread starter Thread starter DHOUGHTON
D
DHOUGHTON
90 MAF Sensor. Where is it?
Also the order of the vacuum lines on plenum?
Thats all.
Marathoner
Vettelt193 said:
I don't think 1990 came with a MAF... I think 89 was the last year until 1994 when they came on Vette's again
Correct 1990 did not have the MAF sensor.
DHOUGHTON, which vacuum lines are you refering to ont he Plenum?
the 2 little ones it will not matter if they are reversed.. the bigger one is for the MAP sensor
Thanks for clearing that up. But what about Vacuum hoses?
On the 90 does MAF stand for
MANUFACTURER ACTUALLY FORGOT ?
MARATHONER
MAP SENSOR Vacuum hose.
I presume it goes in the center of three spots in the plenum since that is where it seems to reach easiest. The map sensor I presume is the little black box that bolts onto the plenum.
I know "GET A SERVICE MANUAL".
MAP SENSOR sounds more like a navigational device. Lets see, where did I put the map?
Thanks,
MARATHONER
Re: MAP SENSOR Vacuum hose.
Thanks,
MARATHONER
The MAP sensor (Manifold Absolute Pressure) is that little black box. the Vacuum line for it should be a little bigger in DIA compared to the other ones.
