spikebot 81
Today I just got back from a well known local engine builder. This is a full machine shop builder with high HP experiance in buisness for 30 to 40 years. I went there to pick his brain about building a sbc engine that would not exceed 400hp for my 81 Vette. We talked quite a while about todays pump gas fuels in old engines with carbs. In a nut shell his opinon, was "Your not going to build a engine with a carb that will make 300hp with the junk gas coming out of the pump. Go fuel injection and modern electronics and I can make you any haul butt motor you want." He also told me that if it where him he would not exceed 8.5 to 1 compression on any engine with a carberator because you'll have to take out so much timing to keep the motor from detination. We all know what retarding the ignition does for HP. So ponder this info from a guy that built engines for some well known NASCAR drivers here in the NW and still building some really fast motors for folks from Seattle to LA .
