UncleBuck
When I put either key in the seat sometimes goes to the memory position but more often than not I need to push the memory button to get it to position. No codes show up. Any ideas?
I suspect this is the answer referred to above:I have the same issue at times?? The answer is?:confused
Tuna said:The memory fuction has to know who put the key in the car - it never assumes.
How do you tell it you are getting in the car? 2 ways - push the unlock button on your fob (even if the door is already unlocked) or push the appropriate memory button on the door. Then it knows that you are getting in the car and will adjust the seat for you once the key is in the ignition and the door is shut.
When you get out of the car and leave it unlocked this happens - right! You get back in, put the key in the ignition, close the door and - there you sit, with the seat full back. Next time, use the fob to tell you Vette that you are about to get in again or remember to press the #1 button on the door.
Just think what would happen if your #2 memory was programmed for full forward seat position and the last person that got out used #2. Then you got in without pressing the button on the fob or the #1 on the door. If the car always went back to the 'last' setting, you'd be squished up against the steering wheel. Not a good thing.
In a related observation, I've noticed that, after a lengthy period of inactivity (sometimes as much as 2-3 months, due to my current job situation), the memory seat system in mine often does not readily complete the "cycle" of moving the seat all the way to the stored position without a bit of "insistence" on my part using the corresponding memory button.
Has anyone else observed that, if the memory seat "function" isn't "exercised" regularly, the movement "cycle" doesn't always complete itself without some additional action on your part? Mine seems to begin working properly once I "exercise" it regularly, so the explanation could be as simple as it's just like any other electrical and mechanical device: they generally don't like to sit idle...?
Yes, I have noticed this. I tried the #2 and #3 memory as a backup but that did not seem to help. Mine will lose the setting and I have to reset it. The seat would move forward and stop short of correct position regardless of memory number used.
Now if it has been sitting for a week or more I move the seat forward slightly with power button before inserting key which completes the memory cycle.
The upside is I have an excuse to drive the car more often.
I had the same thing with my 2003, but it wouldn't do all the time. And then sometimes it would start to go to the memory function settings, then stop halfway and I'd have to push the #1 memory button to get to the right position.
...the Corvette Only technician tried a lot of different things, but since the car was under warranty, GMPP they decided to replace the BCM...
...the cost for a new BCM, tracks and reprograming plus labor came to $2100.00...
Again, sounds a lot like mine.
Well, I don't feel so clueless now, if this behavior stumped the experts...!
Well, let's hope it doesn't come to that; mine's well out of warranty... ! As long as it gets used regularly, it seems to function properly.
Well if it starts to make you crazy, you can turn it off using the DIC !
My 03 will only use the memory feature if I exit and lock the door. When I unlock the door, enter the vehicle and place my key into the ignition, the memory becomes active, my radio goes back to the last active station, my steering column moves out, my mirrors adjust and my seat moves forward. If I do not lock the door but enter the unlocked vehicle and place my keys into the ignition, the easy entry will not work, none of the above functions are active and I have to use the memory button. I believe this is also mentioned in the owners manual. btw, I thought I had an issue as well when I first purchased my 03.
You don't have to lock the door, it's the unlock button that activates the feature. Just press unlock, even if not locked, and memory will function when door closed and key inserted. Or press memory button on dash.
