- Thread starter
- #21
Pinky
About as advisable as mixing .......dfferent oils! ;squint: ;squint:
I don't get it.
Signed,
Blonde AND A Girl
I don't get it.
Signed,
Blonde AND A Girl
Sounds like a good reason to stay with thr run flats too!I have a slightly different issue. Saturday, I had a front GY hit a boulder some kids through in the roadway just before I got there, and when the guy in front of me swerved to avoid it, there it was headed for my undercarriage. I swerved, but it got the front tire and also apparently hit the back. 20 seconds later I got a message that the right front was flat. When I got to the tire store and we looked at it the sidewall was a total loss. I did not see any damage to the back one, and the DIC wouldn't let me get beyond the warning on the front one to see how the rear was holding. I have 13.5K miles on the tires. A new GY will cost me about $400 when all is said and done. Can't tell if the rim got damaged inside but the edge outside looked ok. I toyed with just switching to a pair of Kumhos [for the front to keep the mileage even] which had some good ratings from Vette owners and are half as much as the GYs, but I finally decided to just replace the one bad front tire with another GY. Should I have done it the other way? My deductible was $200 on a road hazard. I also plan to have the undercarriage and front fascia looked at when they get the tire in and it goes up on a lift, and to have the alignment checked, but it seemed to handle ok after the hit.
I'm just not brave enough to do that I guessIf you like driving on rocks. Anyone who likes runflats needs only to drive a non-runflat equipted vehicle, it's like night and day.
I'm just not brave enough to do that I guesshnoes
If they are only about 25%, you can likely eBay 'em and get a decent penny for 'em. I've sold used tires on ebay on multiple occasions and it has worked out pretty well!JNow I like them so much I'm going to switch the fronts even though they are only about 25% worn.
after having driven almost 1,000 miles on a nearly-flat runflat, with no ill effects
after having driven almost 1,000 miles on a nearly-flat run flat, with no ill effects
This is what I'm talk'n about, try that with a non run flat.
No one can argue that one can drive on run flats with 0-pressure. They are design to Run Flat, but to do it for a 1,000 miles??? How can one not notice the low pressure alarm or reduced power, 1,000 miles at 50 or less MPH?
You are absolutely wright that a run flat tire provides unsurpassed safety, especially when there is a pressure failure at higher rate of speed. On the other hand none r/f tires are quieter, smoother and produce better traction. Until someone produces a tire that is a r/f and has same characteristics as a non r/f, one has to compromise and chose safety or comfort/performance. Can't have both. Due to my procrastination I was forced to put none r/f on the rear. I was surprised on the difference in ride they made. Now I have none r/f all the way around. Where I drive my car I'm always with in less than 30 minute AAA service call, so the safety aspect is not so important to me. Both types of tire have good features and one has to decide what is more important. They are both good.![]()
That is my 2 cents worth.![]()
Zig.[/quote
Point well taken Zig, but I will stick with the run flats. I am sure all the things you say are true enough but I still like the added insurance of the run flats. Life is full of trade-offs and I guess I am glad this is one of those things in life that we still have a choice in. AAA is one thing but they still have to take the tire off on the road or load up you machine on a roll back or something and I am not sure I like that idea too much. I would rather deal with a situation like this in a garage some place. So half power, alarms going off tells me the system works at least![]()
Have a great day, and a better tomorrow.
Bill![]()
Just to clarify - I didn't say they had 0 pressure. The actual pressure was between 20-18 psi. The "low tire pressure" monitor went off - once - but the IDIOTIC dealership when I bought the car said it was just the monitor battery failing (obviously they didn't even check the tire). There was a nail in the tire so the leak was somewhat sealed, it took a while for it to lose enough pressure that I finally checked it myself.
Of course a tire manufacturer would never advise to run miss matches because thay want to sell tires.
All things considered, it's correct. Tire compounds and tread pattern each impact the handling characteristics and abilities of the tire. As far as your car is concerned, the road composition under the front tires is the same as that in the rear. Having mixed tires on the car will cause the car, or more so you, to have different tendencies.We do not recommend mixing the tread designs of the Michelin Pilot Sport and Michelin Pilot Sport PS2. On ultra-high performance vehicles like your Corvette, mixing tread designs can cause problems with the vehicles handling and overall performance."
