3782870 was used on nearly all Chevy 327ci small block engines from 1962-64 and part of 65. Look on the passenger side of the bellhousing flange for a cast date code, and on the front passenger side pad/ledge (extension of the bock's head surface) for a pair of stamped number sequences which could yield more clues as to it's origin.
