vetteman741
Hi guys and gals!
I have only had my 98 C5 coupe for 5 days now
(still a honeymoon as far as I'm concerned) and I have not gotten a factory service manual yet so I have a few questions maybe someone could help me out with.
I have a broken bulb and a loose bulb floating around in my pass side front corner lens (thanks to lazy previous owner), I put in a bulb so the light works but how do I get the corner lens assembly out so I can remove the trash from it?
How does the front license plate panel come off, it's loose and I want to fix?
How to the center caps on the original 98 wagon wheels attach, can I just pull them off or will that break something?
Do I need a special harness to connect my Sony aftermarket radio to the factory Bose harness. Can I use my Sony head unit with a built in amplifier and hook to the Bose Harness,can I upgrade the speakers or are they built into an amp assembly----Basically what can I do and not do!
I know I will need an antenna extender for in the dash, it is a short reach, man did GM skimp on the co-ax or what.;squint:
This forum is awesome and I have learned a lot already
, so thanks in advance to you kind people.
Sorry so many questions, I am buying a GM service manual as soon as I get the dough.
