F14JetJock
Hi,
I'm looking for some help or advice with an engine problem. I've called several engine shops in the Ventura CA area. One told me that they don't work on "old" motors (although they might have someone that might work on old motors on his own time) and another told me that they might be able to squeeze me in at the end of 2005 (I thought I heard him wrong and he reiterated it would be over a year before he could get to me) !
I have a 350ci / 350 hp motor cast in 1973, running in my '69. In a forum from last year ... http://corvetteactioncenter.com/forums/showthread.php?t=33451&highlight=valve+cover+blow
SteveL had a similar problem....
I have the same blow by out of the valve cover that he had, the dreaded "puff of death". no water in the oil, no smoke out the pipes. I did a compression check and found one dead cylinder (#3 is 60 psi dry / 65 wet). The other cylinders are all 148 to 156 psi. I haven't done a leak down test because, with a "dead hole", I thought that it would just confirm a bad/burned valve. Mako, in the referenced forum, indicated that he "likes to see north of 150 pounds on a stock engine, and say 180+ on a performance engine". With these compression targets in mind, I suppose I have some leaky rings as well as a bad valve???
Here is the question. How would I trouble shoot these problems, in a logical manner ?
Should I take it to the machine shop to have just the #3 valve fixed (I've checked to see if it was something simple like a broken spring / rocker). I know that most would say, if you get one valve done, get them all done. A valve job might not be the entire cause of the problem. Could a bad valve (60 psi) be the cause of the blow by?
If fixing the valve on #3 cures the blow by and then doing a leak down test checks out OK, I will be able to get a bit more life out of the power plant. If not, then it looks like a complete engine overhaul for the rings, etc. I think I would rather put a crate motor in, since it is not a # matching motor anyway, than do a complete overhaul.
Your sage advice would be greatly appreciated......
