Best Vette Yet
I have a 2003 coupe, done 46000 miles. For a while I have noticed that when the vette is stationary, in neutral, and I rev the motor very slowly, there is a vibration felt which develops around 1300RPM and continues till 1800RPM then seems to smooth out. I also notice that this is the same RPM range used when cruising on the freeway at 70 MPH in 6th gear. Are there any other vettes with the same issue out there?
I also have a whine coming from the car at that RPM. It is not speed dependant but RPM dependent so that sort of rules out the drive train if I am correct in assuming. The whine sounds like the old "diff whine" but it seems to be emitting from the front of the vette. It occurs in the same RPM range as the vibration mentioned above.
There are no codes.
I have done a search on the forum and this seems to be a question other vette owners have asked but no replies have been posted. We would appreciate some thoughts on this topic if possible.
There are no codes.
