- Moderator
- #1
KANE
Moderator
- Joined
- Mar 2, 2002
- Messages
- 3,244
- Location
- KY
- Corvette
- Dark Blue 1982 Trans Am(s): Polo Green 1995 MN6
30+ years on the 82's rear end was a good run.
It was time to get some work done in the rear with shocks, bushings, and the differential. The rear end was coming out and so it was a good time to clean up the somewhat noisy rear end and go to a 3.73 ratio. I had thought about a 3.55 at one time- but decided against it.
I had the OEM 2.87... and with the modified motor, it leaves first gear at 5,450rpm on the 700r4. Along with packing 100+ more HP and almost 100 more lbs/ft of torque... the right gears would help me take advantage of the nearly 500 more rpm in gear and really leverage the motor's HP/TQ curve.
Here's how things fit together modified/stock...
A 3.73 should increase the cruise rpm by about 500rpm. That's fine- at 45mph I am usually in 3rd anyways.
More than anything, the reason for going to the 3.73 was that I wanted to get 1.) quicker acceleration and 2.) to leverage the HP/TQ of the non-stock engine I have.
Since I have an EBL ECM... I have a lot of datalogs that show the acceleration with the 2.87 rear end. In fact, it routinely gets to 60mph on a 90+ degree day, in a hot summer, and even after running it hard for a while in a hair under 6 seconds from a dead stop. I don't drag the car- I just want it to be more responsive.
I should be able to compare pre/post pretty easily from my datalogs.
I'll post more when I get it back together...
- 325hp @ 5,300rpm versus stock 200hp @ 4,200rpm- at 4,200rpm it is already pushing 260hp and still has another 63hp and almost 1,200 rpm to go before it leaves first gear
- 373lbs-ft of torque @ 3,600rpm versus the stock 285hp @ 2,800rpm- at 2,800rpm it is already pushing 350lbs-ft of torque and still has 800 more rpm (before it falls off) and has another 23lbs-ft of torque left to go
- The .465"/.488" cam starts to really come to life at 1,700rpm. That's when the VE starts to pick up (torque) and it holds through 4,400rpm (peak torque) and starts to fall off at 4,800rpm.
