clok1966
I have a 87 with the 4+3 OD manual. Had the car a couple years now and it drovein town 99% of the time. When i bought the car i drove it home (about 100 miles on 70MPH speed limit) I was shocked when i was seeing 26-28 MPG instant, seen 29 even. This was summer, hot day and no wind on flat road. Now putting around town at 30mph i see 28-30 all the time (on long steady stretchs). But my avg is 13.9 (yes i do get on it once and awhile). I had a bad thermostat (found out this winter when i planned a long trip home to parents with it.. couldnt keep it above 110 degrees on road, so no OD, much less heat!) ran great in summer, never overheated or anything.. guess it was a tired old thermostat. Replaced it a few days ago and flushed the coolent. Took car out for first drives this spring (still only 50's here at best). Took it out on road and was getting 18-22 at 75. Now i swear i was in the 25+ range before at 75. No matter what i did i couldnt get past 22, normally was 20ish.
Friend says O2 Sensor may be bad (he thinks it smells rich when he is behind me in town). Old school mechanic (as in i havent done to much on new cars) the O2 the one in the flex pipe loooking thing on passnger side up top? Almost looks a bit like a spark plug?
And one last question.. other then actually getting to um, with aluminuim heads on the vette any problems with plugs? As in stripped threads and the like? I had some old (think K-CAR) chryslers i helped friends with and sad as it is, i can say almost every singel one i ever worked on had a stripped plug in the aluminuim heads.
