Hib Halverson
Don't have images. Sorry.bobchad said:Hib,
Funny you should mention that. I am considering putting in the dual Spals at some point and was considering running a heavy gauge wire up front from the battery into some type of distribution box. I've seen these things where a heavy gauge wire goes in and then there are several posts to distribute the power. How did you do yours? Pictures if you have them please.
Rowdy,
I saw the burnout video from last year. I'm not surprised that you don't hear the hum. :L
Bob
But, the job was simple. I ran an 8ga wire from where the battery connects to the starter, over to the frame then around to the front of the car, to a junction. From there I ran power to the fans (I use a stock, late C4 dual electric fan assembly) and to the MSD with two 10ga wires. The MSD power line has MSD's filter capacitor in line.
The fans and MSD are grounded to the frame up front. The starter case is grounded to the frame at the right side engine mount bracket and I ran a separate negative battery cable from the battery all the way up to the block next to the starter. That eliminates the ground path from the frame back by the battery, up to the engine.
