- Moderator
- #1
vetteboy86
Looking to mount an MSD on the vette. Any mounting suggestions, or pictures of an install?
Thanks, I will let you know how it is going as I get closer to the install.
Vetteboy,I appreciate your reply. But not all of your advice is correct. I had good advice when I installed my msd system. I am experiencing a miss above 4700 RPM's or so. I think it is either ignition or fuel. So a guy at work who has built several motors and currently runs his 9 second car regularly suggested the MSD. I do have electrical background with schooling and my current job, however this install was not a problem at all. MSD makes a wiring harness just for the GM incap Coil HEI system. There is absolutely no cutting or splicing of the stock harness. The MSD harness simply runs from the MSD box, to the coil and then the wires that plug into the coil go into the MSD harness. The good part is that if the box ever did fail, I can unplug the harness and hook stock wiring back up and drive away. I would recommend this install to anyone. If anyone is interested, I could provide part numbers.
A mechanic told me he's seen them l mounted inside the car on the passengers side (up above where your feet go) and run the wires thru the firewall.
I cant see a good place in the engine compartment to mount it and still keep the wires relatively short.
Vetteboy, did you install it yet , and where did you mount it?
Thanks,
Tom
That's where mine is, passenger side, to the right of your feet with the wires nice and short.A mechanic told me he's seen them l mounted inside the car on the passengers side (up above where your feet go) and run the wires thru the firewall.
Thanks,
Tom
Rowdy1, is it noisy?
Tom
