D
Daves85
Hi Guys, Help
my 98 coupe says "pull key-wait 10 sec" so I did..then the DIC says "service column lock" and when I try to move the car the fuel pumps are shutting down and it stalls..
When i bought the car i assumed the column lock recall was done because when i pulled the key out i could hear the column lock motor run but the wheel was never locked.good i assume ?..I see there is a column lock switch that has to cycle off and on for the BCM. Now when i start it i get pull key so i do and then get service column lock.? now when i pull the key i dont hear the column lock motor running at all.? I pulled fuse 25 to reset the BCM if it was locked and that was no good,,same problem and car is shutting down fuel.My codes are B2587 and B2592 which r column locked codes.
Can I fix this myself and what should I do or Buy to fix this.
Thx in advance,,Dave
