74bigblock
So last summer I replaced with new the following:
Booster
Master
Lines to Proportioning valve
Lines from valve to Left & Right Front Calipers
Both Front calipers
Front rotors.
They haven't been the same since, and I think it's either a bad master or the proportioning valve. I just had my local shop pressure bleed the entire system 3 times to ensure that all the fluid was fresh, and there was no air in the lines. With that said... here's what is still happening:
Symptoms:
With car off, pump up pedal... good for about 3 pumps... then it goes soft. It does not come back until I start the car, then turn it off again.
With the car running, the brakes function, but do not have great stopping power, and I'm getting a ton of squeal out of the front.
Any thoughts??
Thanks,
Dave
			Booster
Master
Both Front calipers
Front rotors.
Symptoms:
Any thoughts??
Thanks,
Dave
;help
