S
Scott81
Ok all you super mechanic types, as some of you know I just had a complete rear end rebuild done on my 81. Here's the problem; driving at slow speeds I had a clunking noise in the rear, since everything was new I figured it was just something that needed to be tightened up, maybe the front pinion mount. WRONG! It's the freakin' right side yoke on the differential. I had the car up on jack stands after I tightened everything up and was just checking to see if there was any play in the NEW wheel bearings, turns out there is some in/out play in the yoke.
Anyone have suggestions? Can I replace this without pulling the entire rear again? Right now I just plan on trailering the car up to Van Steel and telling them to fix it since everything is new and I've put less than 100 miles on it.
AAARRRRRGGGGGGG! I could just shoot something right now!
I guess I'll just have to let this guy do it for me for now. If anyone needs me I'll be in the garage pacing the floor with my Colt .45
