- Thread starter
- #21
V
vette-dude
Again, do consider having your machinist check angle/fit of intake to heads. And … have a Q&A w/ speed shop where heads came from … regarding any surfacing/milling/mismatch/ new v. rebuilt v. “seconds
Heidi,
I forgot to add that the heads that we put on that 406 were brand new DART heads. Soooooo, Since you have it all apart it would be wise just to be sure and check this dimension during re-assembly. As for the cam, if you call competition cams in Memphis, they can put some data you need to provide in the computer and come up with the best bang for your buck. Pertinient data would include engine size, trans type, vehicle weight, tire size, rear end ratio, RPM range, use of vehicle, carburation, modifications to engine, etc. Lunati can do the same and they are also in Memphis. Careful with going to big as then you will have to have a stall convertor if you are running an Automatic. And yes you can get the manifold gasket out of whack when you install the intake but I think you should make sure that your angle is correct on the mating surfaces or it will just do it again. Remember, if you don't have time to fix it right the first time--When will you have time to do it over?? Good lUck.
Randy
... for not considering your Goodwrench might've come with shallow (~0.165") oil ring groove and low tension expander ... rather than the more conventional deeper (~0.200") oil ring groove. And ... it seems you did have a ring problem on #4 after all. When y'all recycled the old rings (with shallow, low tension expander) onto the replacement piston ... you had about 0.035" too much back clearance on the oil ring ... probably made for lousy oil control.
ad
