damoroso
I'm outta ideas, I hope someone out there can help. I have a stock 81 with about 65K miles on it that I bought in January (This is my second 81, I've had a 65 and a 67 as well). I can't get the a/c to get any colder than 66 going down the road with the a/c on max.
Here's the story. A few months ago, the a/c wasn't getting as cold as is should have so I replaced the hotwater shut off valve, as that seems to be a part that fails fairly often and it's not very expensive. That didn't work.
I took the car to an a/c "expert" and he informed me I needed a new compressor. It was original and was making alot of noise, so I agreed and decided to change over to R134 at that time. He replaced the compressor and the dryer/accumulator. Then just a couple of weeks ago I took it back to him and he replaced the clutch fan. Still the sytem only got down to the mid sixties. He tried several times and told me that's as cold as it gets, because this is an old car.
Next. The next "expert" I brought the car to this last week, re-wired the electric fan so it comes on any time the ingnition is on, telling me that moving air across the condenser would fix the problem. At least that's what he told me when I picked the car up. Nope. Still the best it'll cool is 66.
I've check all the vacuum valves, the outside air, and vent, are working as they're supposed to, I've seen them. They also seem to be sealing. The duct work under the dash is intact, and the hotwater valve is getting 20+ inches of vacuum when it's supposed to close.
I'm outta ideas and it's freakin hot here in Florida!!!!!
Anyone got any ideas?!?!?
