gmjunkie
Well Do what you must,but if you don't change the accumulator you have just wasted your time!!! If the screen was black,thats ground up descant,Not Only will it Not Cool right,It will Kill your compressor over time!!!When the screen gets as bad as the one I pictured,It's TOO Late!! You need to change the schrader valves to,there less than $1.00 each and they have descant stuck in them and there leaking!!Small snags.
1) I don't own a wrench big enough to get the inlet/outlet lines off of the accumulator. They're bigger than 1 inch, and that's all i have. (let the jokes begin). I can borrow one or go buy some. But that's not going to happen until tomorrow.
2) There is almost no room to move a wrench on the upper fitting (the one coming into the side, not the one on the bottom). I can get a wrench on it (if I had the right size) but it is wedged between the coolant reservoir and the evaporator housing. I don't think I can spin a wrench even if I get on it.
I can solve the first one, but the 2nd one has me stumped.
Any suggestions?
I did get the orifice tube replaced. Mine was black, but not covered in crud like the one in your pic. The new ford one went in a lot easier than the old one came out (just as a note, the Ford one I got (i triple checked the part # so I know it is correct) is orange, not blue (different manufacturers)).
I found something interesting in the shop manual:
"The accumulator should ONLY be replaced when:
1) a physical perforation to the accumulator is found resulting in a leak
2) the expansion (orifice) tube screen experiences continued or repeated plugging
3) The compressor inlet screen is plugged (A6 compressor)
4) An evaporator fails because of inside-out (internal) corrosion"
Part of me is tempted to go with the manual and not rip the flesh off of my knuckles trying to get a wrench in there.
Please Help!!!
Just be glad you don't have to put a Evaporator in it,You'd get the remove the Exhaust Manifold,Valve Cover and the Rocker Arms off of 6 and 8 to get the case out!!!!
PS Why don't you remove the screws out of the coolant tank and drop it down out of the way??It's been a while,but if I remember right you can take the triangular plate off the bottom of the fender and drop it clear out of there!!
