minifridge1138
I will take a look tomorrow and let you know the high and low side pressures with the blower disconnected (as soon as I find the connector).PS I need the High & Low side pressures after it's unplugged while A/C is running!!
Also just as well leave the gages on it,we will probly be doing more tests!! Plus I have a few more questions!!
6. When retrofitted,was the accumulator drier replaced??:confused
7. Was a New Orifice tube Installed??:confused
8. If so was there any trash in the old one??:confused
9. Was the complete system Flushed with 134a Compatible Flushing solvent??:confused
10. Was the old refrigerant oil dumped from the compressor and replaced with 134a compatible oil??:confused
11. What condition is the fan Clutch??:confused Is it Loose,does the fan have any front to back movement??
12. Is it Thermal or Friction??:confused Thermal will have a flat coiled spring on the front side!! Kinda like a Carburetor Choke Spring!!
My Toll Free is 1-877-677-2984 if it makes it easier!!![]()
answers:
6) I did not do the retrofit myself, so I don't know what was replaced.
7) Don't know. Is there any way to know without taking the system apart?
8) Don't know.
9) I replaced the ac compressor about 1 1/2 years ago. It held a vacuum for over an hour. At that time, I put oil in system along with the freon (I had a more experienced friend help, so i'm not sure how many oz we put in).
10) When I put oil in, it was 134a oil.
11) AC clutch is fine. The engine fan (the one mounted to the water pump) is also fine.
12) I assume you are talking about the engine fan, it has the spring on the front, so I assume it is thermal.
I really appreciate all of the help so far, and can't wait for more great advice. I will take notes of what I do and the results so that I can post them here for others.
Thank you very much.
