Bill: Cant wait..
As an example, what would the experts here say to this:
As per my ALDL data, my Battery Voltage says 17.6 at startup then goes to 5.6 and stays around the 6's (5.9, 6.3 etc) while i drive and back up to 18.6 before i turn it off..
Battery or Alternator ? CAN that affect Idle performance (car running in general) or not? Lights are usually on, no radio on, no AC or fan. No additional accessories aside from what GM put in the car.
or offend anyone...and maybe that was simply mis-worded, but that statement is incorrect. The only thing varying battery resistance will change is alternator CURRENT output...from Ohm's Law: current = voltage/resistance (assuming the resistance does not drop to a point where the alternator's maximum current capability is exceeded...for example a dead battery). The same thing will happen when other loads are applied, like turning lights on...etc. More load = lower total resistance = higher alternator current output.
