I'm getting ready to flush and change the brake fluid on a 1998 Corvette that I recently acquired.
I've done this numerous time successfully on my 1979 Corvette using a hand vacuum pump at the caliper bleeder, maintaining the master cylinder full with fresh fluid, and pulling the new fluid through the system with a vacuum, and thus forcing the old fluid out. But my 1979 doesn't have computers or ABS brakes.
I'm getting conflicting info on the brake fluid replacement process for the 1998 C5.
Initially I was told that the procedure I used on the 1979 Corvette would work fine on the 1998 Corvette???
Then someone told me that I shouldn't use the hand vacuum pump, that only a master cylinder pressure bleeder should be used???
Someone else told me that I had to disconnect the battery before performing brake fluid flushing to avoid setting off some diagnostic trouble codes???
Someone else told me that the brake fluid flush was a dealer-only job because of potential damage to the ABS controller???
NEED SOME CLARIFICATION IF POSSIBLE!
I've searched the previous threads but can't find a clear answer.
Is there someone that has performed this brake fluid flush on a similiar year C5 Corvette........ that can enlighten as to the correct steps/procedure to accomplish this task my a "do-it-yourselfer"?
Hopefully using a hand vacuum pump (which I have) at the caliper bleeders.
(In my rural area I don't have a local Chevy dealership I trust with Corvette work).
THANKS MUCH
Craig W
THANKS MUCH
Craig W
