M
mike weyman
hi guys, i need some help.i am lowering the rear end in the 75 to install new seals and universals.
i removed the half shafts,drive shaft, and the bolts that go up onto the frame.
one side can be pushed off the mount,but goes right back in, the other side won't let go.i need to drop it about three inches to get the end off the rear.
the shock absorbers are still attached,I also have the exhaust lowered out of the way.
is there a way to beat these friggers out,the only tool i havent resorted to in order to lower this part is the cutting torch,or the ball peen hammer .
the shocks will have to be removed, but that's not holding the crossmember.
if anyone can help,or has an idea(other than bigger hammers or flame throwers)i would appreciate it as this is the last big hurdle before the restart.mike
