Zo6 LVR
1995 LT1 55,000 miles. Up until a couple of weeks ago I have never had a problem with my engine. I changed the plugs with the OEM Delco plugs. No problem for a while but just yesterday when headed for the Bloomington Gold show I noticed only when the A/C is on at idle in drive the engine misses frequently. A/C off or in neutral with the A/C on no miss. I realize that with the A/C on there is more load and apparently just enough to cause the miss. I have not changed the plug wires or cap & rotor or the opti unit. If it is a bad plug or wire, what is the best way to isolate the culprit? Or any other thoughts anyone may have as to the cause of the miss or related cures.
