80convertible
- Joined
- Jan 26, 2001
- Messages
- 416
- Location
- Asheville, NC
- Corvette
- 1973 converted to 1980 custom convertible
Got the 95 Trans Am dual electric fans, but have no real wiring diagram to work from. I already purchased an adjustable electric fan thermostat wiring kit and seperate 30amp relay. The adjustable thermostat kit uses a sensor installed into the fins of the thermostat as opposed to a sensor that screws into the manifold or block. Anyone forsee a problem with this setup? Also, do I just insert this sensor right into the radiator fins? What I really need is simple wiring directions to wire all this together. Anyone out there got some experience they wish to share? My a/c is not functional, so I don't need to wire it into the electric fan wiring harness until sometime later. I read that when installing dual fans, they should be installed via a relay instead of directly to power source because of amps they draw. Any help would be appreciated, especially a wiring diagram.
Regards,
Jim
Regards,
Jim
