goingballistic
OK this is now becoming a lesson in frustration !
I'm on the last part of the rebuild and putting on the pulleys etc. I've got two problems that you guys ( and gals) may be able to help with.
1) The pulley for the crank is a Summit billet pulley. The mount bolts are non standard size, I think I can handle that one but after mounting the pulley it doesn't line up with the water pump pulley. the guys at Summit said "no one makes" a pulley for a crank on a vette that will line up with the short water pump for the vette ( 81 vette). SOMEONE has to make a pulley for the crank, twin vbelt, that lines up with the EDL 8822 water pump and pulley. The only way to correct this is to place spacers between the pulley and the damper. Apparently the Vette 350 front is differnt length from water pump mount to pulley than a standard 350. Anyone dealt with this before?
2) I was also just informed that the 7 quart Milodon oil pan I installed won't fit in the engine bay ad and the tech guy at Summit said "yea those kids that sell parts don't know this stuff". Anyone and I think I asked this before installed a 7 quart in an 81?
Paul.
Paul.
