TAC
- Joined
- Feb 18, 2002
- Messages
- 252
- Location
- Bothell, WA
- Corvette
- 1987 Yellow Callaway TT Convertible & 2003 MY Z06
I replaced all the turbo lines and got my clutch fixed so I finally took the TT out on a 500 mile shakeout. Everything was fine until I got home and put it back on the lift. The oil cooler radiator looks like it has been sprayed with road oil. It literally looks covered from head to toe. However, the lines and fittings going into it look really dry. They're not leaking. It just looks like the cooler core is letting oil sweat out. Does this sound familiar for these things? I should add that none of the surrounding area is coated with oil so it didn't come off the road. Even the radiator area behind the cooler is dry. Only the cooler radiator portion is covered in oil.
Does anyone know the part # for the oil cooler and where I can get one? It sure looks like an easy fix. I took the body part off right below it and it looks like the whole unit is fixed to the body with 2 bolts. Thanks in advance.
Tim
87-092
Tim
87-092
