Needed, master cylinder rebuilder recommendations
Trois Rivieres, Quebec, Canada
63 Resto Coupe-Red 65 Roadster
If you send your m/cylinder to most any supplier, they can have them rebuilt and sleeved, however I would like to go to their source.
Has anyone gone through the process, and if so, with who. ?
Stepinwolf
IH2LOSE
We Will All Meet Again
1966,and a 1962 thats almost complete
never used these guys but hear good things about them
http://www.whitepost.com/brake.html
Brian
I used these guys a couple of times now. For me there no other place to go. Send it it out to them, next thing you know you have it back. I have always had fast service from them. Also let them know what finish you want on it when done
Tom Bryant
Administrator
Edgerton, Ohio, United States
1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
It seems like every time this topic comes up on any Corvette site that White Post is recommended. I have never used them but they have an excellent reputation as a restorer and rebuilder of components.
solidaxle
Ohio
54,54,56,58,60,60,61,62,62,63,63,64,66,02
I only use Brake & Equipment Warehouse, 800-233-4053, ask for Rob in the shop. They use stainless sleeves vs. whitepost's brass/bronze. They also guarantee the cylinder when using silicon brake fluid, Whitepost warranty is voided if you use silicon. Plus Whitepost doesn't do their own work, they send it out. I hear it goes to a guy in Florida.
I had nothing but headache's from Whitepost... cylinders leaking, check valves missing, etc. They wouldn't stand behind their warranty and Billy just laughed! Been using B&E for the past 2 years, They've done about 10 masters for me, and dozens of wheel cylinders. Less expensive than Whitepost.
Washington, Michigan
'67 Marina Blue Convertible
Billy at White Post has done about a dozen master cylinders for me over the years, plus two car sets of priceless/irreplaceable 60's Ferrari aluminum master and slave cylinders and aluminum calipers. Never had a problem (they do the work in-house). :)
solidaxle
Ohio
Then they must be good. Just keep B&E's number handy!:upthumbs
White Post, at least 2 years ago sent some of their work to Ed Strain, in FL.
See these issues on various AACA forums:
http://forums.aaca.org/showflat.php...Words=whitepost&topic=&Search=true#Post372588
http://forums.aaca.org/showflat.php...Words=whitepost&topic=&Search=true#Post300574
http://forums.aaca.org/showflat.php...Words=whitepost&topic=&Search=true#Post214657
Also might want to search whitepost on the CCCA forum. Their issue with silicon fluid is rather well known.
Thank's to all who took the time to respond.
I spoke to White Post, and for his 150$ + charges, ( small, single master cylinder ) it turns out to be more profitable to sell it as a core with the booster, rather then having it rebuilt.
Regards
Stepinwolf
G
groovyjay
I would just buy a rebuild kit, send the MC unit to a local machine shop to get it honed and put it all back together myself.
