smithjw
I just bought a new 100amp alternator needed to supply enough power to my audio equipment. I also got a Painless performance alternator wiring kit for high output alternator's. The diagram that is supplied with this kit shows that the output wire from the alternator should run to a maxifuse (heavy duty 50amp fuse) and then onto the starter solenoid. Now, upon checking the current wiring on my car, it seems that the alternator output wire runs directly to the battery compartment behind the driver seat and goes into what looks like a small distribution block, and then onto the positive battery cable. This wire already appears to be an 8 gauge wire. So, the question is, do I really need to do any re-wiring, and if so, what wires need to be beefed up? Why is my current wiring not like the supplied wiring diagram. Has someone possibly rewired my car before I owned it?
Thanks for any help on this.
