NOTHING CHEAP! A PORT JOB ON THE STOCK TPI WILL BE THE BEST BANG FOR YOUR BUCK IF YOUR ONLY LOOKING FOR MODEST GAINS, BUT IF YOUR LOOKING FOR MAJOR HP/TQ YOULL NEED matched CAM,HEADS,INTAKE, AND EXHAUST SYSTEM COMPONENTS
the standard stock STEALTH RAM WILL NOT FIT UNDER A C-4 CORVETTE HOOD,IT REQUIRES A CUSTOM PLENUM,BUT THE RESULTS ARE WORTH THE TROUBLE!
THE MINI RAM COSTS ABOUT $1200 (CORVETTE FUEL RAILS)
bye the time you get fuel rails, ETC.
THE SUPER RAM about $1300 (with ACCEL base runners,plenum)
THE SINGLE PLANE ABOUT $900 (YOU NEED NEW FUEL RAILS,REGULATOR,THROTTLE BODY, TPS) and depending on what intake you might need a new distributor
THE custom STEALTH RAM about $800 plus small base distributor
the, ported TPI, super ram and STEALTH RAM SEEMED TO BE the best choices Ive found, AFTER TRYING SEVERAL HEADS, CAMS,ETC. BUT the heads flow numbers , converter stall speed, cam, duration, displacement , compression ratio,and rear gearing your corvette has should determine your choice ,should you choose to upgrade from the stock TPI, which is a good intake in the under 4000rpm range, but hopelessLY RESTRICTIVE for max hp, the MODIFIED SINGLE PLANE INTAKE WORKS FINE BUT IS NOT COST EFFECTIVE AND LOOKS WRONG, IN FACT MOST PEOPLE,EVEN PEOPLE WHO DID NOT KNOW ANYTHING ABOUT CORVETTES SEEMED TO KNOW SOMETHING LOOKED WRONG!
the mini RAM WORKED FINE BUT AT LEAST ON MY ENGINE TENDED TO BE QUITE PEAKY IN THAT IT CAME ON STRONG ONLY AFTER 5000RPM AND COST MORE THAN THE OTHER INTAKES I HAD TRIED
I CURRENTLY AM RUNNING A CUSTOM STEALTH RAM, AND IT AT LEAST ON MY ENGINE COMBO HAS THE BROADEST AND HIGHEST TORQUE CURVE AND BEST SEAT OF THE PANTS FEEL PLUS ITS RUN THE BEST ET OF ALL FIVE
your combo will of course differ at least slightly
ID JUST SERIOUSLY PORT THE tpi IF I WAS LOOKING FOR UNDER 4500RPM PERFORMANCE ON A STOCK DISPLACEMENT 350 ENGINE ON THE STREET
ID PICK THE SUPER RAM IF i HAD A 350-406 WITH STOCK HEADS AND MILD CAM
ID PICK THE STEALTH RAM IF I HAD A 350-406 WITH HIGH FLOW CYLINDER HEADS,AND CAM,WITH AT LEAST 220 DURATION, AND WAS LOOKING TO MAKE POWER IN THE 4000RPM-6500RPM RANGE
