- Thread starter
- #21
Kenney
The bleaching is on the outside…the inner (covered) portion is fine, just past the plastic paint protector where the roof sits and stops where the permanent rear deck starts. Only there and no where else on the car. My plan is to take the advise of another CAC member and try buffing it out over the winter…worse case scenario new paint in the spring. If I knew the cause, I could attempt to keep it from happening elsewhere. There is no peeling and it’s original paint, just a fine haze. The rest of the car has a high glossy finish. Acid rain? (but the rest of the car would be effected). Thanks for the interest, by the way you have a great looking car. I have always had a soft spot for the rims on the '88
RJSROCKET said:Welcome to another Canuck! I have near the same car and I have to wonder why only the deck within the perameters of the top is affected. Mine shows no difference other than the ring it gets where the seal rests, and that is easily buffed away with a soft cloth. If anything, one would expect the deck within the roof area to be in better condition than the rest due to the top protecting the top cover from the sun. Is there any sign of peeling or a paint change in the past or?
