Marv02
New Motor willn't start Why
I totally lost.
Just put the engine and Trans back into the Vett and hooked everything up and No Joy it won’t start cranks fine just won’t start.
I made sure everything was TDC both valves are shut on number 1 cylinder.
Made sure the rotor in the distributor was pointing to the correct plug wire lug in the distributor cap.
Did a compression check 120 on every cylinder?
Pushed the bleed valve on the fuel rail fuel coming out of it.
New Fuel pump.
So I have compression fuel and great white spark coming out of the plugs there self.
I tried starting fluid still nothing.
Still not running.
I going to try to put the old know good fuel pump back in tomorrow see if tis i fix anything.
Anyone out there has any ideas why this motor won’t start.
HELP
I totally lost.
New Fuel pump.
Still not running.
HELP
