F
fc3
Hey Guys, I have some new questions from my engine builder. I have asked him lots and now he wants to hear some from ya'll. I will paste his e-mail on this posting. Thanks for everyones help. Fred.
Fred,
Well...I just spent some time comparing the Edel RPM heads to the AFR's.
Edel RPM:
170 cc in port
64 cc ex port
64 cc chambers
AFR 180:
181 cc in port
? cc ex port
68 cc chamber
AFR 190:
191 cc in port
? cc ex port
68 cc chamber
I compared the flow #'s of these heads, using the CHP mag test info, and here's where things get interesting:
At .400 in valve lift, the AFR 180 had +12 cfm in, and +36 cfm ex flow, over the Edel.
At .400 in valve lift, the AFR 190 had +26 cfm in, and +31 cfm ex flow, over the Edel.
The 64 cc chamber Edel head yields 10.8 compression with a .030 piston, and 0 deck height, and .039 gasket.
The 68 cc AFR head yields 10.3 compression with a .030 piston, and 0 deck height, and .039 gasket. (You will loose .5 point compression with the AFR's).
Now, the 190 AFR heads come highly recomemded, and their in ports are 21 cc bigger, so of course their flow #'s will be higher. Also, in this test, they used a 76 cc chamber AFR head, that further unshrouds the valves, so of course the flow #'s would be higher still. (Not a good comparison, in my opinion).
Low-mid rpm power making street engines often need smaller ports for higher airflow "velocity" to fill the cylinders, and high cylinder pressure, (more compression), at low and midrange rpm for torque. You could have them mill the AFR's down to 64 cc, but this would require a .024 flat mill. This, combined with the possible .015-.020 or so block mill, would probably require special length pushrods to reset the valvetrain geometry, and a possible extra intake side mill, to get everything to fit and line up right, and there must be enough piston valve relief for proper clearance also. (No big deal, but more time and $).
In my opinion, 170 cc would be enough to support 383 cubes at 5,500 rpm, and I really can't understand how 21 cc more volume intake runners would be higher velocity. The AFR's must have a really good ex port though, or, are they just bigger?
So, the big question is, will these AFR heads make more low and midrange power/torque to accelerate your 3.08 geared street friendly vette, from idle to 5,500 rpm faster than the RPM heads? I would really like to see some real life proof, to make the right decision!
Why don't you post this on the vette board, and see what their thoughts are. And tell them our intent is not to flame anybody, or prove them wrong, you just want some opinions on these points, and you value their imput. I would like to see what some experts have to say. This should be very good info for other people on that board, as well. Let's see some pros/cons.
Mike
Fred,
Edel RPM:
170 cc in port
64 cc ex port
64 cc chambers
AFR 180:
181 cc in port
? cc ex port
68 cc chamber
AFR 190:
191 cc in port
? cc ex port
68 cc chamber
Mike
