CROOZ1N
OK, I bought a couple of new keys with the correct resistance chip in them to have spares cut before I loose my only set. I went to Advance to get them cut but instead of risking one of my VATS keys to check I had them cut a non VATS key to check and see if it would at least turn the lock cylinder. It will not.
Is that because of a bad cut, difference in the key or because it is a NON VATS key. To my eye the cut looks good but there is a slight difference in the back end of the blank.
