RedvetX2 said:
OK Now that you have determined that you have FE1 the next question is how fast do you get rid of it.
My bet is the first time you go over a harsh bump in the road and your car changes lanes without notice you will be looking to improve to Z51 and dumping the runcraps.
Look around the forums for help. Almost Any tire is better than the runcraps and just changing to Z51 sway bars will be a Huge improvement
I disagree. While I don't have lots of experience driving other suspension/tire combinations, I don't think that the FE1 package with runflats is all that bad. After purchasing my Vette, I first had to install new shocks, so I went with Bilstein Sports. And the tires that came on it from the original owner are Firehawks, not Goodyear F1s. Other than that, the suspension is the stock FE1. I'm able to go around turns with complete confidence, and it corners like it's on rails. I'm sure the Bilsteins help for bumps in the corners, but I doubt the stock shocks give up so much on the Bilsteins as to be considered poor handling.
I also don't have a problem with the tires. Again, I haven't done A-B comparisons, but I don't notice any handling or noise/ride comfort issues with my Firehawk RFTs. I can't comment on the Goodyears, but I doubt the Corvette team would have put a Vette on the road with truly pathetic tires.
I have considered adding Z06 or Z51 swaybars to my FE1-based coupe, but that will probably not be any time soon. I just don't feel that Z51 or better is imperative for getting a thrilling, enjoyable ride out of one's Corvette. I'm sure Z51, Z06, or F45/55 Sport makes it even more fun, but FE1 is already a helluva good ride. After all, they're all still Corvettes...
So, 99C5Coupe, enjoy your FE1 because it's already a fine suspension. If you want to get more sporty or racy, consider stiffer shocks and sway bars.
Have fun!
Fred
