I
ike
Got a question for anyone out there that can help. Haven't had any problems with my vette in quite some time now so i have been fixing little things that have been needing some attention. I drove the car home from work yesterday and worked on fixing the dome light. Easy fix-replaced the fuse. I had problems reading the fuse panel so I pulled out several other fuses and put them all back into their proper place. Dome light fixed -and moved on to the power antenna. Tore the console apart to get to the relay and ran out of time because it got dark on me. Went to start the car up this morning and the motor will turn over, it get fuel to the carb, but no spark. I went back and checked all the fuses, everything good. I looked at all the wire connections under the dash and in the console but I dont see anything disconnected or shorted out. Any suggestions? I feel I have knocked something loose but can't find it. It was fine UNTIL I tore it apart-always happens to me like that.
Any help would be much appreciated. Thanks-IKE
